nissan primera p12 aftermarket headunit |
Post Reply | Page <12345 9> |
ragt20
Admin Group Swiss Tony Joined: 02 May 2003 Location: Other Online Status: Points: 69654 |
thats top stuff mate...
itnorfolk
NPOC Guest Joined: 14 May 2012 Location: Great Yarmouth Online Status: Points: 28 |
Hey guys,
I'm just wondering if it would be possible to rip out the sat nav and cd unit and install a standard H/U? I'm in a 2002 T-Spec 2.0....
imckay
The DVD drive powers the screen, radio/CD and climate.
You may be able to remove the radio/CD. All the P12s I know of with a standard headunit, have kept the existing setup in place (sometimes relocated) and tap into the power and speaker wires. |
itnorfolk
Ah ok, I was hoping to leave the CD unit and screen and simply remove the DVD drive...
I guess the best thing I should do is disconnect it and test it all, then if it works its cool, if it doesnt work I can simply reconnect :)
We can save you that trouble now, you can not remove the sat nav dvd player as said above the electronics supporting the above go through the sat nav unit
itnorfolk
ohhh! tut, bugger, how about cars without the dvd/sat nav player? is it totally different wiring loom etc?
imckay
Yes, different loom on the non-Nav version.
If you just want a different or additional CD/Radio, that should be possible. |
Kaisersose
NPOC Guest Joined: 07 Jan 2014 Location: UK Online Status: Points: 13 |
Hey guys, I followed this guide and successfully installed my aftermarket head unit.
Just to let you know, you can get an ISO cable now. I got mine for around £8 from a popular auction site. It's listed as '05 primera onwards but it worked fine on my '04. I will try and post a couple of images |
Kaisersose
This is the ISO cable connected during installation... http://i647.photobucket.com/albums/uu194/kaisersose_2009/478448da20ebc4b41148044c5db9fb11.jpg Installation completed! Thanks for the guide |
Kaisersose
