Nissan primera P12 battery problem |
abba
NPOC Guest Joined: 10 Jun 2012 Location: chester Online Status: Points: 25 |
Posted: 11 Sep 2017 at 8:19pm |
Hi
Do these cars have an inherent problem of discharging the battery ? Twice in last three months mine has go e flat being g unable turn the engine over,all I get is clicking noises like cellanoids going off Any ideas please |
i know very little about a lot
Maybe you have a intermittent battery drain?
Also how old is the battery? |
roy.2
It's also getting to the time of the year to find out if your [and other peoples] battery is good or not.
So, no there is not an inherent issue with P12s over any other vehicle. If the battery charging light is not on that should be able to rule that issue out leaving either an open circuit or a battery at the end of its life.
d60_tag
NPOC Guest Joined: 18 Jul 2015 Online Status: Points: 533 |
Swap over to another battery and see if things improve...
... if the replacemnt drains/ does the same- look elsewhere for the reasons/ drain. |
