Nissan Primera P12 Electrical problems |
Absent
NPOC Guest Joined: 21 Nov 2017 Online Status: Points: 1 |
Posted: 21 Nov 2017 at 4:16pm |
Hello. I recently bought a Nissan Primera P12 that has something wrong with its electrics. Nothing used to work except the headlights and tailights. When you try to start it nothing happened, not even a single light on a dash showed up But then I found out that someone had removed the comfort module and after I put it back in, some stuff started to work like hazard lights, brake lights, only driver window and a couple more things. But the car does not even appear to want to start. I checked the fusebox, fusible links and all that stuff but I could not find what is wrong. And when I connect the battery, I can hear clicking noise coming from the center of the dash. What could be the problem? Maybe someone has come across the same problem and knows how to fix it?
Hi and welcome to the forum,
if you get rapid clicking it normally means your battery is goosed, the P12 recognizes when there is not a enough juice and will power the ancillaries but will not engage the starter.
\have you checked the fuses in the engine bay as well as the ones in the cabin?
Estyfort
NPOC Guest Joined: 16 Nov 2017 Location: Lagos, Nigeria Online Status: Points: 116 |
What is the status of your security light when the ignition is turned to the ON position? Does it go off or it stays on?
