  New Posts New Posts RSS Feed - Nissan Primera P12 engine sump
roger land View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote roger land Quote  Post ReplyReply Direct Link To This Post Topic: Nissan Primera P12 engine sump
    Posted: 08 Jun 2019 at 1:46pm
Hi everyone.  Can anyone tell me please how easy is it to remove and replace the engine sump on a Primera p12.  Do you have only to remove the plastic undershield and then the sump bolts or is there anything else to remove.  Incidentally do I need any special tools.  Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote p11primeragt Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2019 at 9:27pm
Depends on which engine it is?
Post Options Post Options   Thanks (0) Thanks(0)   Quote roger land Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2019 at 9:38pm
It is 1800 (1769?) petrol
Post Options Post Options   Thanks (0) Thanks(0)   Quote p11primeragt Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2019 at 9:46pm
No special tools needed..
The exhaust downpipe needs to be dropped so the sump clears the oil pick up when putting it back into place otherwise you'll struggle.
So that and the undertrays.
The bolts will come out easy but the sump might take some getting off,so give it some taps carefully with a rubber mallet and if need be try to pry it apart along the joint,be careful with the timing cover though its so easy to crack it..
Post Options Post Options   Thanks (0) Thanks(0)   Quote roger land Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2019 at 9:59pm
Thanks a lot for information and finally does it have a normal sump gasket or do you have to buy some special sealant when fitting a new one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote timeshock! Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2019 at 10:22pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote p11primeragt Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2019 at 11:00pm
Use Rtv Sealant.
