Nissan primera p11 electric problem. Tail fuse |
primera p11 97norway
NPOC Guest Joined: 27 May 2015 Location: norway Online Status: Points: 16 |
Posted: 22 May 2017 at 4:57pm |
Nissan primera p11 97mod sedan. Electric problem with tail light circuit. Fuse ceeps Blowing.
Hi. I need some help to diagnose and fix the electric problem on the tail light circuit. The fuse ceeps blowing all the time. I have been trying to find a direct connection between the positive side on the battery and ground to indicate a direct connection between them and a possible ground fault with my multimeter by using ohm. This with no luck. I have messured the tail light bulb connections with ohm. They all have a direct connection with ground. I guess it should be like that becouse when the relé to the tail light goes on the current reaches the bulb and the tail light. Or could this be the fault? Anyway, i need some help to find this fuse problem, if any of you guys have some tips on how to fix this problem i would be very thankful. |
In fact. All the wires have connection with eachother on the tail lightbulb connection socket...
