  New Posts New Posts RSS Feed - Nissan Primera P12 2005 sudden wiring problem?
brickbat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brickbat Quote  Post ReplyReply Direct Link To This Post Topic: Nissan Primera P12 2005 sudden wiring problem?
    Posted: 04 Mar 2018 at 8:48pm
For some reason when I lean forward onto the steering wheel or if the road is bumpy my cd player turns on.  If its already on, it restarts the song.  It started doing it after a service from the authorised service center in Amsterdam.  I would have taken it back but I had it serviced just before exporting it so now its in another country.  Does anyone know if there is an easy fix for this?  If not, how much would you expect it to cost to be fixed?
All the Best
bb.
Post Options Post Options   Thanks (0) Thanks(0)   Quote timeshock! Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2018 at 9:15pm
Depend what the fault is. It might be the loom on the steering wheel it affect the last accessory used. e.g. if it was the air con and you had changed the temp it would affect that. the loom replacement is by Nissan only, don't know the cost but I would always advise to ring around a few.
On the other hand id it is definitely bump that does it and it is only the DVD then who knows if it is the player, wiring or button.
Post Options Post Options   Thanks (0) Thanks(0)   Quote brickbat Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2018 at 3:40am
It definitely doesn't change anything but the cd player/radio. And I'm not absolutely certain about this but I think it may happen more often in sub-zero weather.
Post Options Post Options   Thanks (0) Thanks(0)   Quote timeshock! Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2018 at 6:53am
when mine went it started with either cold or damp weather. I would just make a habit of using the aircon as a last function before driving and checking it out
