  New Posts New Posts RSS Feed - Nissan Primera P12 Heater problems...
 Post Reply Post Reply Page  <12345 9>
arnie 818 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote arnie 818 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 12:59pm
The part number is 27761-AV600
norbert eggcup View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norbert eggcup Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 8:39pm
it would seem on P10, P11 & 144 models the fan will still work on highest speed whereas on a P12 it stops working altogether
the spaceship and the P12
rainbow View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rainbow Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2010 at 3:35pm
Hi Guys,
New member here. Have problem thats looking for a solution!
Heater not working though fan is.
Also reverse parking camera now very grainy and picture bounces!!
Any advice would be appreciated. 2004 1.8 se (petrol).
paul martin
coldgal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coldgal Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2010 at 6:38pm
SmileSmileSmile Thanks for the info everyone was telling hubby on the parcel shelf side the air has been blue until I found your information. He's now a happy bunny and am going to be a warm bunnyBig smile
PaddyM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaddyM Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2010 at 3:18pm
I wanted to post my experience which should help out P12 owners.
  • Blower unit stopped working.
  • P12 has 5 settings - blower didn't work on any (as per mentioned in post above).
  • Got a mechanic to check the blower, was working ok.
  • Mechanic told me I probably needed a resistor board.
  • Came on here to check it out - got a bit confused so rang nissan to ask their advice.
  • Told me most likely a resistor pack so I ordered one.
  • Arrived today - the unit is actually called a Module Assy-POW. £46.17 including vat.
  • It is the part with the white connector behind the clutch pedal mentioned earlier in thread.
  • Replaced it and the blower is now working ok.
  • No sign of damage etc. on old unit.
I have uploaded some pictures which can be found here which should help you out:
http://www.flickr.com/photos/47295551@N00/sets/72157623982489211/
Post Options Post Options   Thanks (1) Thanks(1)   Quote imckay Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2010 at 6:37pm
Some dealers suggest changing the pollen filter at the same time. Maybe a blocked filter causes extra load on the motor and blows the fan control module?
Orinoco View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orinoco Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 3:31pm
I took my Primera into the main dealer near me to get it fixed today and they quoted me £185 for the module, air filter and fitting. I now wish I had followed the advice above and fitted it myself.
fossyant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fossyant Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 7:42pm
Ah, there is a fair amount for labour there though..... at dealer rates...................
deano235 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote deano235 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2010 at 3:04pm
hi there iam enquiring for my grandad about his nissan primera heater, demister isnt working you can turn it up down on fan speed but no difference i know the blower is working, and was wondering if it would be the same problem as  paddy m has posted so can anyone help ?? thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote ragt20 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2010 at 10:03pm
what version of primera has he got, depending on that could be one of two things, on the earlier primeras its usually the heater resistor card, about £35 from nissan. for a P12...it could be what has been said earlier in this thread
