Fans not working for heater / cooler? |
Post Reply | Page 12> |
Graeme 1
NPOC Guest Joined: 17 Sep 2011 Location: Oamaru New Zeal Online Status: Points: 6 |
Posted: 17 Sep 2011 at 10:00am |
Hi to the members of this forum, I have never been involved in a forum before so hope I do the right things.
I have recently bought a 2002 Primera saloon and the fans for the heater / cooler in the car have stopped working. I have checked all fuses and none appeared to be blown. Not sure what the next step is. I would think that there would be a resistor for the control of the fan speeds but can't find anything that looks like one. Was wondering if there was any one that has had this happen and what the fix would be. Tis a great car but this was a dissapointment. I am still trying to find a wiring diagram that I can follow through to try and find the bits. Thanks to those for reading. Graeme.
Geordie
NPOC Member Not in Estate Joined: 27 Feb 2009 Location: Coffee Machine Online Status: Points: 12214 |
Hi, and welcome to NPOC.
2002 was a changeover year for the Primera's, so it would help if you could let us know what version you have....either P11-144 or P12. Are the fans not working on any setting? |
Car of the Month April 2010 (Black GT)
Car of the Month August 2012 (Red Wagon) "You are a one man, used car industry, improvement system!!" - Tom (12/12/16) Current: 1991 P10 2 litre GS |
norbert eggcup
NPOC Guest Swiss Tony Joined: 06 Dec 2006 Location: in a civic Online Status: Points: 4464 |
taken from the invisible "how to..." section
http://www.npoc.co.uk/forum/forum_posts.asp?TID=12795&PID=185415&title=p12-fan-speed-control-module-diy-repair#185415 check and change the pollen filter while your at it |
Graeme 1
Well that was a silly mistake on my part!!! My car is a p12. The fans do not work at all. The airconditioner is switching on; the radiator fans switch on but we have no fans internally. We have only had it 3 months so it is a bit of a let down.
Regards Graeme.
Welcome to the forumIt is not the end of the world it is a cheap fix. The fault is sometimes attributed to a dirty pollen filter and hence why it is mentioned above
Graeme 1
Thanks to those that have given me the the good info. I have priced a new part and shock!!!!! they were wanting just over $500-00 N.Z. Priced the part and it was $6-60N.Z. Next job to repair myself and be smileing again. I will also check the pollen filter. This has been the best meeting of people I have had for many years. Look forward to keeping in touch in the future.
Regards Graeme.
Good result. good luck with the repair, just give England a supporting cheer down there though
Graeme 1
Hi Geordie, I have now repaired the control unit and at no cost as it appears that there was just a dry joint. All the help and advise I have received from this forum has been absolutely great. We now have a great heater in a great car.
Regards Graeme.
ragt20
cool to hear you got the problem sorted and got some heat, though would have thought in a place like NZ, you would prolly need the AC working more..:)
Graeme 1
Hi all this is the P12 from way down under again. I am being hopefull here that there may be a way of getting the navigation system working in our car. As we get imports in from Japan I am looking to see if there is any guidance from someone who to contact or a way to get it working. Seems a shame that this great car now has the good stuff but it will not work down here in New Zealand. Been trying to find information about this here but to no avail. Hope to here from someone that this is an easy fix just like the fans were.. I am all eager to have the car and all its facilitys working.
Regards Graeme. |
