p10-p11 part combatibaility |
P12FTW
NPOC Guest Joined: 01 Jun 2009 Location: Bumpkinshire Online Status: Points: 52 |
Posted: 04 Jun 2009 at 12:39am |
Hey all
I got a p10 Primera (GA16DE) and wondering what parts I could fit on the p10 from the p11 since p11s seem to be more common for breaking. I know the rear suspension is different (but what about the front) as well obviously the body panels (due to length). But what about say the seats or interior parts? Or anything from the SR20DE I can fit on to the GA16DE? Any infos would be helpful. |
GaryeGT
NPOC Guest Guinness Gaz Joined: 30 Jun 2008 Location: Limerick Online Status: Points: 11356 |
well it really depends on what exactly you need..... like the suspension is far different front and back, yet the top links are swapable, the engines are pretty much the same.... body panels are a no obviously.... so best option is tell us what ya need to swap and we cann tell ya if they swap
P12FTW
Alright then.
Im looking to swap parts like the: interior seats wheels suspension (what parts are doable?) steering wheel door cards brakes (worth doing tho?) engine (any parts compatible with the GA16DE) So, whats doable here then? P.S. Any parts of the eGT/eZX that are worth fitting would also be worth knowing. |
modsman
NPOC Elite Member Joined: 30 Dec 2003 Location: back on mars Online Status: Points: 11283 |
ok.. the seats wont fit ..
wheels will
suspention no...
steering wheel .. yep
door cards.. nope
brakes...yep
engine .. if it's a GA16DE ..yep ..
Skymera
johnbr6
NPOC Guest Joined: 09 Feb 2008 Location: Anglesey Online Status: Points: 15702 |
front ones will aye
P11 SRi
prim-n-proper
NPOC Guest Tick Tock Tick Joined: 28 May 2007 Location: oop north Online Status: Points: 18737 |
not a straight swap though
COTM: MAY 2006 P11 GT
COTM: MAY 2009 P11 SLX+ COTM: AUG 2012 P11 WAGON LAST EVER COTM: NOV 2013 P10 eGT Your "other car" might be newer, but it don't make it better than a P chassis.*PNP17* |
P12FTW
Cheers Modsman.
May stick with 14" wheels so cant really nick the larger brakes from the GTs, and just get parts from eZXs and eGTs. Unless I can source some nice 15" steelies or summat. However, what parts from the later 1.6 engined P11s are different and worth putting in my 1994 1.6? According to Wikipedia: http://en.wikipedia.org/wiki/GA16DE The later ones (p11) have better cams and better intake despite lower output? Any clarification would help. |
P10 > P11 > P11 144 > P12
