Nissan Primera P10 eGT wiring question. |
Foxn
NPOC Guest Joined: 09 Feb 2011 Location: Veurne (B) Online Status: Points: 7 |
Posted: 12 Apr 2011 at 6:38pm |
My SR20DE lowport is dead. Ik have a donorcar that holds a highport SR20DE the question is, will i just have to replace the ECU or does the whole wiring harness has to be replaced also? the lowport is a redtop from a p10 1994 thx in advance! |
ragt20
swap over the engine, you don't need to swap the ecu
Foxn
Thank you for the quick reply! |
Foxn
After having a very busy time at work I found some time to work on my car. Apperently the wiring isn't the same. the lowport has more connectors. Should i only change the cabletree in the enginebay? than i don't have to get the dash and stuff out to change the inside cabletree also. Thx in advance |
ragt20
interesting to know that there is a big difference in the wiring between the two...have you tried to compare the two sets of wiring looms and try and see which connections are extra? and yeah you would only really need to change whats in the engine bay are, not everything inside the car.. |
Foxn
i did some research and some say it's because the sensors on my lowport are ODBII But i thought this was only on the RR engines. tomorrow i'm gettings my engine harness from the highport next to the lowport version. It's storede at a different location. Thx for the quick reply mate! |
ragt20
non of the P10s have OBD II so it can definately not be anything to do with that.
Foxn
That's good to know. everything is in my workplace now. if i have some spare time this weekend i can compare the 2 engine harnesses
