nissan primera P12 CAMSHAFT SENSOR |
Post Reply | Page 123 4> |
foxhole
NPOC Guest Joined: 21 Jun 2011 Online Status: Points: 94 |
Posted: 27 Jun 2011 at 8:47pm |
What is it's purpose, mine may be faulty, is it an urgent fix?
Nissan Primera S - 53plate 2-litre Estate
ragt20
Admin Group Swiss Tony Joined: 02 May 2003 Location: Other Online Status: Points: 69654 |
yup it would be an urgent fix, as it will cause your car to run crap, and if the fault gets worse not run at all...
essNchill
Moved from New Members to section to here, the General Section.
norbert eggcup
NPOC Guest Swiss Tony Joined: 06 Dec 2006 Location: in a civic Online Status: Points: 4464 |
check with dealers if your car had the recall carried out for the engine position sensors
foxhole
How does sensor cause engine to run poorly?
heathf
NPOC Guest Joined: 02 Jun 2008 Location: Bournemouth Online Status: Points: 46 |
I had a simmilar problem with the Crankshaft Position Sensor in my P11-144. I had to fork out £107 for a pair of sensors but it did do the job. The ECU requires both Cam & Crankshft sensors for the engine to run. If one of these fails there is no output to the Tacometer and the engine stalls. The sensors, athough they look idential, are not interchangeable. You can swap them over for test purposes & get a signal out of them but the engine will not run. Using a Laptop Soundcard Osciloscope application is a very cheap way to diagnose sensor malfunctions where dynamic signals need to be monitored. In my case the sensor took 20 minutes of driving before it went dead. Once cooled it started working again. The position of the Camshaft sensor is on the lefthand side of the engine near the top, it's easy to change.
The sensor signals will be active when the ignition is on & the engine is rotating. They should look like the folowing photos when viewed on an osciloscope (green = Camshaft sensor): |
colmoneill
NPOC Guest Joined: 28 Jun 2011 Location: Ireland Online Status: Points: 68 |
"Using a Laptop Soundcard Osciloscope application is a very cheap way to diagnose sensor malfunction" this sounds very interesting, can you explain how to do this ?
Ant-Dat
NPOC Legend 1998 Primera GT Joined: 15 May 2003 Location: In workshop Online Status: Points: 16125 |
SB "he isn't human, he is a machine that never falter |
foxhole
Do Nissan charge much to do stuff under a recall notice? Norbert mentioned one which might cover it?
When I purchased the car it had a service bill which states a problem with cam sensor. |
Baz007
NPOC Guest Joined: 15 Mar 2007 Location: Lancashire Online Status: Points: 1613 |
Recall work will be carried out free of charge...
Cam and Crank sensors are NOT the same! |
