  New Posts New Posts RSS Feed - My car stall for no reason. Problem starting
Conride View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Conride Quote  Post ReplyReply Direct Link To This Post Topic: My car stall for no reason. Problem starting
    Posted: 11 Nov 2018 at 8:16am
Hello Guys,
I am  new member from South Africa. I drive a Nissan Primera P11, sr20 engine. The car shut down sometimes for no reason, sometimes when I start it doesn't start after I drove it for a while. It cause me to wait for it for couple of minutes and it start again. When I start it has a smell of petrol. Others say it overflows. Not sure because I am just a good driver. Please help.
I will appreciates your concern.
Regards,
Conride.
Cs
Post Options Post Options   Thanks (0) Thanks(0)   Quote p11primeragt Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2018 at 12:45pm
Since you smell fuel if could be the maf if it's a 144.
If it's a p11 it will be the coil inside the distributor failing. You'll smell fuel from repeated attempts to start it,will start and run for a while when the coil has cooled again.
