Nissan almera 1.8 sport 5door 02 |
Post Reply | Page 12> |
Kevin H
NPOC Guest Joined: 16 Feb 2017 Location: Sunderland Online Status: Points: 8 |
Posted: 16 Feb 2017 at 7:04pm |
Hi hope i can get some help my nissan almera rear heated window
Switch works on and of fuses are ok I Think it might be the Relay switch it clicks when the heater switch lights up cant find The relay switch i hear a click right hand side beside fuses so dont know if it is switch on dash or relay gratefull for any help Cheers kevin H |
keithSRI
NPOC Member Joined: 21 Jun 2008 Location: Milton Keynes Online Status: Points: 2401 |
Welcome to the forums. Can't provide any advice myself but sure someone will be able to help soon.
Kevin H
Thanks keith any way hope you are right
Electrolyte
NPOC Guest Joined: 12 Aug 2011 Location: Ba-Bru City Online Status: Points: 1368 |
From 2001 service manual
The rear window defogger system is controlled by the time control unit. The rear window defogger operates only for approximately 15 minutes. Power is supplied at all times + through 20A fuse [No. 7, located in the fuse block (J/B)] + to rear window defogger relay terminal 5 (B7 relay models) or 3 (B6 relay models) + through 10A fuse [No. 13, located in the fuse block (J/B)] + to rear window defogger relay terminal 6 (B6 relay models). + through 15A fuse [No. 5, located in the fuse block (J/B)] + to time control unit terminal 9. With the ignition switch in the ON or START position, power is supplied + through 10A fuse [No. 10, located in the fuse block (J/B)] + to the rear window defogger relay terminal 1 and + to time control unit terminal 1. Ground is supplied to terminal 5 of the rear window defogger switch through body grounds M28 and M67. When the rear defogger switch is turned ON, ground is supplied + through terminal 3 of the rear defogger switch + to time control unit terminal 3. Terminal 13 of time control unit then supplies ground to the rear window defogger relay terminal 2. With power and ground supplied, the rear window defogger relay is energized. Power is supplied + through terminals 5 and 7 of the rear window defogger relay (B6 relay models) or + through terminal 3 of the rear window defogger relay (B7 relay models) + to the rear window defogger and door mirror defogger. The rear window defogger has an independent ground. With power and ground supplied, the rear window defogger filaments heat and defog the rear window. When the system is activated, the rear window defogger indicator illuminates in the rear window defogger switch. REAR WINDOW DEFOGGER System Description The relay is behind the dash side lower RH finisher. The time control unit is behind the lower instrument panel close to the steering wheel column.
If in doubt give it a clout!
To find which relay it is,touch them one at time while you operate the switch,you will be able to feel it working.
Electrolyte
B6 relay is for cars with heated mirrors and B7 is for without.
Kevin H
Thanks Electrolyte i will look at that still not shure if
The switch is faulty or it is the relay is their any way Of testing switch |
Electrolyte
Looking at the diagram, if the switch lights up then that would rule out the switch, the time control unit and the relay as the relay powers both the light in the switch and the window heating element. I would suspect a bad connection at the glass itself. Look for blackening at the spade terminal where it connects to the glass. You could also meter the connection to check for 12 volts.
Electrolyte
Another possibility is a break in the wiring harness where it passes from the roof to the tailgate. The wires can become brittle and break with constant opening and closing.
Kevin H
Thank you very much mate i will give that a try thank you so much
