nissan p12 high pitched alarm sound |
Post Reply | Page <12 |
Hi and welcome to the forum both of you
The P12 is very susceptible to changes in voltage and as the wire carry signal around the car to the ECU strange things can happen. In most instances it is a poor earth or blown bulb. In this case it is the door lock
I recommend you download the free electronic service manual following the link below http://www.npoc.co.uk/forum/nissan-primera-factory-service-manuals_topic29493.html Go to page BL119 you will need to to check the connector, power and operation to determine where the fault lies |
fattyinadatty
NPOC Guest Joined: 27 Jan 2014 Location: norfolk Online Status: Points: 2 |
Thanks for sharing the link unfortunately i am unable to download it at the moment ! Will try later when you say the door lock is at fault do you mean the boot lock/press button may have a earth fault or the needs replacing - i assume this will then cure the number plate light once plugged back in many thanks for sharing your help
lovekesh
NPOC Guest Joined: 28 Jan 2014 Location: Bristol Online Status: Points: 2 |
Thanks a lot, I could download the document. But unfortunately could not relate the back door handle at page BL119 with boot opening switch of my primera P12.
wickydude
If you downloaded the most recent version including the 1.9 dci, there are actually two versions of the BL section, the numbering is not the same in both.
To get the switch out, you need to remove the finishing trim on the inside, then remove the license plate finisher (which unforunately unbolts from the inside, hence the need to remove the trim on the inside). There are crossreferences to the EI section to help with that. |
angelina12
NPOC Guest Joined: 27 Oct 2007 Online Status: Points: 17 |
high pitched continuous alarm sound, when key is in ignition which dont go off at all, boot wont open off key fob but works off door switch, alarm sound goes off when indicators are on or hazard warning lights on. has anyone found a fix for this please?
Thanks(1)
Have you tried the earth fix?
wickydude
Thanks(1)
Probably faulty boot opening switch or in the wiring of that switch. The car thinks someone is trying to open the boot while the ignition is on.
