Nissan Primea p12 1.8 starting issue |
L30nkj
NPOC Guest Joined: 22 Jun 2017 Location: Sa38 Online Status: Points: 2 |
Posted: 22 Jun 2017 at 10:29am |
Newbie to the primera. I bought a car locally as a stop gap. I have my current car for sale but can't be without wheels. It was brought home 10 days ago and parked up. Yesterday I went to start it and it had a flat battery. Stuck the charger on and come back an hour or so later. Disconnected charger and tried to start it. It turns over but does not start. Is this a common issue / something unusual that I might be doing wrong?
Immobiliser light is off, seatbelt connected, gearbox in neutral Thanks in advance |
Hi and welcome to the forum
You have probably flooded it, pop out fuse 17 just loose just hold it there, turn the car over until it catches and push the fuse in, it should fire.
L30nkj
If that doesn't work then the cam chain may of stretched. Does it appear to spin over fast at times?
