Nissan primera 2002 braking problems |
Post Reply | Page 12> |
Natnatot
NPOC Guest Joined: 15 Aug 2016 Location: Essex Online Status: Points: 28 |
Posted: 18 Feb 2017 at 5:38pm |
Hello everyone. I have majoy braking problems with my p12. Its a nissan primera tspec 2 litre petrol. 2 outta 4 bleed niples will bleed. The other 2 wont. Drivers back will wont. Passanger front wont either. We have tried everything and got know where. Both the Calipers were seized but there not now. Any help please?
keithSRI
NPOC Member Joined: 21 Jun 2008 Location: Milton Keynes Online Status: Points: 2401 |
Sounds to me like new (used but refurbed maybe) calipers may be in order. Someone else may be along soon with a different idea though!
Natnatot
Thank u. Got another caliper on the front but thats not giving anything. Back one has given me about 20 ml of fluid then stopped
I take it you have been topping up the brake reservoir when doing the bleeding?
Have you try to open the bleed nipple a little further? |
BlueSlug
NPOC Guest Joined: 02 Feb 2017 Online Status: Points: 14 |
have you tried removing the nipples to see if they are blocked.
otherwise to me sounds like a block somewhere else. |
Natnatot
Hey guys. Yup kept her topped up. Bleed niples are fine also.
Natnatot
Perhaps i should mention i have a spongy brake pedal
Spongy brake pedal is just air that is trapped in the lines.Could be a faulty brake compensator.
Natnatot
Where can i find the brake compensator?
Electrolyte
NPOC Guest Joined: 12 Aug 2011 Location: Ba-Bru City Online Status: Points: 1368 |
Brake compensator ??? Pretty mutch old hat , and misleading , not applied on P12. All built in. Had it on my very old Vauxhaul Astra Estate and when mechanic messed with it car sat on its arse like a dog dragging its bum. It was an extra box at the rear axle and was supposed to prevent the car rear brakes coming on before the fronts. When I had to replace the rear brake cylinders on my Renault 19 the compensators were incorporated within the cylinders themselves. Spongy brake can be caused by worn Master cylinder. Suggest you simply google spongy brakes and educate yourself.
If in doubt give it a clout!
