nissan primera 2004 se automatic losing power |
craigoneil
Non Member
Points: 45 |
Topic: nissan primera 2004 se automatic losing powerPosted: 04 Feb 2012 at 3:49pm |
hi there when im driving my nissan it starts to struggle to go fast it does worse at the light when you pulling away
Points: 7149 |
Posted: 04 Feb 2012 at 8:19pm |
Craigoneil...not been funny like but you have posted loads of times on this subject one of them back in August last year and now you have started another thread on the same subject. It is not giving us much of a chance of answering and finding the solution if we have to start all over again asking for information, not knowing what you have tried and what has not worked.
Saying you have started this one again why not collate all the answers you have had and what you have tried to date and maybe we can get the problem sorted once and for all
craigoneil
Non Member
Points: 45 |
Posted: 05 Feb 2012 at 11:49am |
ok
craigoneil
Non Member
Points: 45 |
Posted: 05 Feb 2012 at 11:53am |
this completely differnt fault from the last time that why a started a new post as ive not had any advice back from the other posts
craigoneil
Non Member
Points: 45 |
Posted: 05 Feb 2012 at 12:13pm |
ive also been told it could be the Maf sensor would this be right and how do a check it
Points: 7149 |
Posted: 05 Feb 2012 at 1:07pm |
If this is a separate power issue to what you had what are the difference and what did you do to fix it the last time?if it is at pulling away have you considered the clutch? try pulling away in 2nd on an incline, does it pull, any juddering or squealing, any problem with selection of gears?
As for the MAF only way is to change it and they are not cheap.
craigoneil
Non Member
Points: 45 |
Posted: 05 Feb 2012 at 1:41pm |
only problem i had before was overheating got that sorted had to get a new rad for the car
now ive got the problem lossing power the engine type is qr20de petrol 1.9 h.cvt automatic if this helps anyone a striped down the maf and cleaned the sensor on put it back to geather then went on a drive to see if it had it was ok but was still happing how much would it be to get one and is hard to fit |
