Nissan Primera Owners Club Nissan Primera Owners Club > General Open Forums - NO TRADING! > General Section
  New Posts New Posts RSS Feed: Nissan Primera P11 144 1.8 Timing Chain???
  FAQ FAQ  Forum Search   Calendar   Register Register  Login Login
sparks View Drop Down
Non Member
Non Member
Post Options Post Options   Quote sparks Quote  Post ReplyReply Direct Link To This Post Topic: Nissan Primera P11 144 1.8 Timing Chain???
    Posted: 09 Mar 2010 at 11:07pm
This is my first post, so apologies if I B*lls it up.
I have a 99 V reg. P11 144 1.8S (engine code QG18DE) with 130K on the clock. I've owned the car for several weeks and up 'til now it's run pretty well.
I drove the car to work today and again during my lunch break, however during the journey home (approx. 10 miles) the engine started to judder/miss-fire.
On the driveway it continued to miss-fire whilst idling and continued to do so when I took it out for again this evening; however, on the way back home everything seems to have returned to normal??
I've read the posts about coil packs, MAF's and sensors, but the one I dread is the timing chain!! Any advice is most welcome, thanks
Post Options Post Options   Quote essNchill Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2010 at 11:10pm
Hi there and a big welcome to NPOC,
If the chain was goosed or stretched it wouldn't be these symptoms.
My money (as you already know) would be on a dicky coil pack or MAF.
Enjoy the forums and take care,
Pretty In Pink - 89 Loon - essNchill Edition
Non Member
Non Member
Post Options Post Options   Quote sparks Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2010 at 11:19pm
Hi Shaun, thanks for the welcome.
How can I tell if it's a coil pack? I haven't lifted a spanner in anger in more than 20 years and my knowledge of cars, up to now, has been limited.
Stevie J View Drop Down
Non Member
Non Member
Post Options Post Options   Quote Stevie J Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2010 at 11:25pm
Coil packs are built into each spark plug lead on the 1.8 engine. You can see them on the top of the engine rocker cover - they ared secured with a screw to the RC and pull out of the block exposing the spark plugs. They are prone to failure and can be bought from Ebay fairly cheaply.
The next time it misfires, disconnect each one, one by one and see which one, when removed makes the engine run no worse - this will be the faulty one.
Check the contacts between the coilpack and the spark plug for damage or looseness too.
Sometimes, the misfire will be so bad that it makes the MIL light on the dash flash on and off, with an error code corresponding to the faulty coilpack.
Post Options Post Options   Quote essNchill Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2010 at 11:29pm
Clap Thanks Stevie - You saved my fingers.
Non Member
Non Member
Post Options Post Options   Quote sparks Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2010 at 11:33pm
Stevie J, you say to check the contacts between the coilpack and the spark plug for damage or looseness. Sorry if this is a lame question, but do i undo the screw securing the coil pack and then check for looseness or do I check it while it is still secured?
So far I've not had any warning lights come on. How do I know that the MIL light is connected and that someone hasn't removed the bulb. Also, do the error codes appear on the dash?
Non Member
Non Member
Post Options Post Options   Quote sparks Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2010 at 11:39pm
Could my problem have anything to do with pressure washing the engine on Sunday?? The engine started straight away afterwards and ran OK up until 5ish today?? Could it just be a coincidence??
stonegrey View Drop Down
Post Options Post Options   Quote stonegrey Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2010 at 6:44pm
It could well do, may have taken some time for any water to get into the connections for one of the coils, or even between the coil and the plug.
now may be a good time to take each coil out, clean it down with WD40 or similar, wipe off with a dry cloth. Then re-assemble.
A Factory Service Manual for the 144 can be downloaded here:
not sure if non members can see the "how to" section but if you can, download it.
Non Member
Non Member
Post Options Post Options   Quote sparks Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2010 at 9:50pm
I'm going to try to get a coil pack from ebay or the breakers yard.  Are there lots of types to choose from? Do they vary according to engine size and spec. i.e S, SE?
Confused
This page was generated in 0.188 seconds.
Copyright (c) 2001-2010 Nissan Primera Owners Club. All rights reserved.
