  New Posts New Posts RSS Feed - Nissan Primera P11 1.6 GA16DE - wierd noise
p11p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote p11p Quote  Post ReplyReply Direct Link To This Post Topic: Nissan Primera P11 1.6 GA16DE - wierd noise
    Posted: 07 Oct 2014 at 4:48pm
Hello All!
I hear some wierd noise from my beloved Primera P11's (1.6 GA16DE) engine.
The symptom:
- I start the engine, everything is fine
- the engine starts to heat up, it's OK
- when the rpm goes under 1000rpm, I hear that some wierd noise appears
- when the engine reaches the normal temperature and the rpm goes decreases to the minimum (6-700rpm), then this certain noise is continuous.
But:
- if I push a little bit the accelerator pedal, (just around 1000rpm) the noise disappears
- if I drive 20-30 minutes, the noise often disappears (not always, but often.)
I recorded a video, would You be so kind, to check it, please?
http://www.youtube.com/watch?v=7RMzSrDf9AU
The following parts are replaced:
- the alternator (it has a certain problem, so I had to buy another one)
- when the alternator was changed, I asked the mechanic to replace the belts (because this was my first thought as a possibility).
No change.
Then mechanic checked the source of the noise with a special tool and sad that the sound comes from somewhere here:
The ideas were:
- let's change the oil in the servo
- maybe the water pump should be changed.
So, fresh oil and new water pump - but no change. :S
Then we were talking about the timing chain. Can it be, or not? The mechanic said that in his opinion this part could be the source of the noise:
About the timing chain:
- the engine always starts for the first time, works very smoothly, during driving I can not feel anything wierd and fortunately no "engine check" lamp. I just hear this noise when the rpm is under 1000. But I don't like noises like this. And I would like my lovely Nissan to be healthy.
Do You have any hint or similar experience according to the video?
Any suggestion is appreciated!
Thank You in advance!
Grim View Drop Down
r1pp3R
Post Options Post Options   Thanks (1) Thanks(1)   Quote Grim Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2014 at 5:25pm
I suspect you have bad chain or guide maybe both. Simply remove your aux belts then start the engine. If the noise is still there you can rule out the alternator , aircon pump ect .
No signature allowed!
RS Tom-Hundred View Drop Down
Condiment King
Post Options Post Options   Thanks (1) Thanks(1)   Quote RS Tom-Hundred Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2014 at 5:27pm
Hi and welcome to the club Smile
My first thought was start of water pump issue but that is obviously not the problem if its been replaced.
The chain on the GA engine is much less prone to rattle noise than the SR20 as it is two chains rather than one long one (and this is less of a rattle noise anyway and more of a rubbing maybe)
Wouldnt have thought it was anything as major as the part you mentioned as I would expect a louder noise probably.  Could maybe be a tensioner or guide catching on the chain but would think it would be not just at that rpm range.
Long shot but are there any pipes or wiring that are in contact with any of the belts by mistake and causing the noise?
pragmatist_m View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote pragmatist_m Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2014 at 7:39pm
I suspect your flywheel is bad/damaged. Thats how my P11-144 was bringing a weird noise.We didnt identify the source until the engine stopped starting. Lo and behold, when scanned and checked, flywheel and totque converter were damaged.
I suggest that you have the professional go under the car and inspect that area well.
Your car's problem may be solved if you don't give up.
p11p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote p11p Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2014 at 9:00pm
Thank you very much for your help and ideas!
I wouldn't think it's a flywheel problem, because that is on the other side. This noise comes from the right side of the car, it's 100% sure. No doubt about it. That's why I placed there the camera.
I'm sure nothing is in contact with any of the belts.
Well.. I keep thinking...
Nnist View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Nnist Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2014 at 12:49pm
Propably upper chain, my ex-Primera made the same noise and it became almost intolerable until I got rid of the car.
dwbman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dwbman Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2017 at 6:35pm
Hy!
I have a Nissan Primera P11 with GA16DE engine. There is a same phenomenon in my car than was at you. Your story is an older one, therefore I hopeful that you found the source of the weird sound. If you so, please tell me what is the solution. Thank you!
Post Options Post Options   Thanks (0) Thanks(0)   Quote pragmatist_m Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2017 at 2:19pm
The weird noise was from damaged flywheel. You can ask your mechanic to check that.
