Nissan Primera P11 - ABS light code |
Post Reply | Page 123> |
ahmed bossman
NPOC Guest Joined: 12 Dec 2015 Location: Bristol Online Status: Points: 143 |
Posted: 16 Jan 2017 at 10:54am |
i posted on here about my ABS code, cant seem to find the post...
first code - 1 long flash followed by 2 short flashes. second code - 3 long flashes and 1 short flash i cannot 100% remember the second code but its something like as above. is there somewhere where i can find the location for the meaning of the different codes? thanks |
'98 DR2 Green Primera P11 GT - Track car
'98 AJ4 Flame Red Primera P11 GT 2014 Blue Vw Move Up! - Track Car 2009 Milano Red Honda Accord ES GT Insta : @ahmed.bossman Youtube : shorturl.at/glzWY |
First one is no fault found.That always comes up.
Second one would be open circuit in rear right hand wheel speed sensor. But yesterday you said it was 40 which you must of miscounted as there's no code for 40. |
ahmed bossman
thanks, i cannot fully remember the second code, i will have to re-scan. to be sure.
what would the code be for the front left sensor? i have a feeling its the nearside front, not the offside front!? |
ahmed bossman
is there somewhere which has all the codes so that i can check for myself? just curious...
ahmed bossman
may sound like a daft/silly question, what is the difference between an open and short circuit? what could be the solutions to both? thanks |
http://www.bba-reman.com/gb/content/nissan_abs_ecu_fault_codes_for_nissan_almera_and_primera
ahmed bossman
whats the difference between an open circuit and a short circuit? what could be the solutions to both scenarios?
A failed sensor could cause a open or short.
If you have got a open circuit you may have a damaged wire or poor connection. If the ABS light is on all the time then 9/10 it's a sensor.If it's intermittent(when turning the steering lock to lock) it's cable related. If you get pulsating brake pedal when coming to a stop it's likely to be the ABS reluctor ring. |
ahmed bossman
i am 100% sure that the rings are fine, after inspection!
abs light has come on and stays on. would a clean of contacts rectify the problem? i have ordered replacement abs sensors regardless! |
It be one of the sensors then in that case.Dont waste anymore time on looking for things.
