  New Posts New Posts RSS Feed - nissan primera p11 engine problems
deano501 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote deano501 Quote  Post ReplyReply Direct Link To This Post Topic: nissan primera p11 engine problems
    Posted: 07 Feb 2015 at 9:44am
my 1.8 p11 2000 model starts and runs fine until after about 3 miles then cuts out and wont restart until its been left for about half an hour.. ive changed the coil packs but nothing has changed. could this be fuel related or is there another common fault that could be causing this.. its a petrol model.. thanks deano 501
Post Options Post Options   Thanks (0) Thanks(0)   Quote deano501 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2015 at 12:54pm
i have now changed the fuel filter and still the same thing is happening.. rather stuck now any ideas... thanks deano501
Post Options Post Options   Thanks (0) Thanks(0)   Quote p11primeragt Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2015 at 5:34pm
Have you got the engine management light on?
Sounds more like faulty cam or crank sensor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote deano501 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2015 at 6:28pm
yes the light is on on the dash..
are the cam and crank sensors an easy diy fix or is it a trip to the garage.
Post Options Post Options   Thanks (0) Thanks(0)   Quote p11primeragt Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2015 at 7:34pm
Both sensors are just plug and play.
Best getting a cheap diagnostic scanner which plugs into the diagnostic socket,it will tell you the fault code.Therefore no guessing.
TheStigP11GT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TheStigP11GT Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2015 at 11:48pm
The Bluetooth elm scanner works well for Android connectivity to get EML codes.
---Current Cars---
Primera GT - SR20VE.N1 / Qashqai 1.5 N-Tec K9K / Pulsar 1.5 N-Tec K9K
http://www.neovvl.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote deano501 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2015 at 9:37am
Thanks are the sensors the same as when looking up both they look indetical to each other.
Post Options Post Options   Thanks (0) Thanks(0)   Quote imckay Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2015 at 10:02am
You can run a self diagnostic to get the fault codes.
You just need a thin piece of wire.
Diagnostic port is below the fuse box to the right of the steering wheel.
http://www.npoc.co.uk/forum/p11144-diagnostic-check-clear-and-codes_topic8946.html
Or get an OBD2 Code reader.
redshark1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote redshark1 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2015 at 6:44pm
Its been said on here the sensors are the same. Possibly the wire length could be different but not sure.
See my Nissan Primera P11-144 common faults and fixes guide:
Post Options Post Options   Thanks (0) Thanks(0)   Quote deano501 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2015 at 6:53pm
THANKS GUYS FOR YOUR HELP. CHANGED THE CAM SENSOR THIS AFTERNOON AND EVERYTHING SEEMS TO BE FINE NOW... IS IT WORTH DOING THE CRANK SENSOR ASWELL JUST TO BE ON THE SAFE SIDE...    DOES THE ENGINE LIGHT NEED RESETTING OR WILL IT GO OUT BY ITSELF? MANY THANKS ONCE AGAIN FOR YOUR HELP.. DEANO501
