  New Posts New Posts RSS Feed - Nissan Primera P11 GT - MOT failue **Help Me Pass*
ahmed bossman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ahmed bossman Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2017 at 10:40am
Originally posted by bavs83 bavs83 wrote:
Perhaps look on the breaking car thread and see if you can find anything?!?!?!
have you got a link, not sure i've come accross it yet...
'98 DR2 Green Primera P11 GT - Track car
'98 AJ4 Flame Red Primera P11 GT
2014 Blue Vw Move Up! - Track Car
2009 Milano Red Honda Accord ES GT
Insta : @ahmed.bossman
Youtube : shorturl.at/glzWY
Post Options Post Options   Thanks (0) Thanks(0)   Quote ahmed bossman Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2017 at 10:44am
just successfully ordered complete lower control arm with ball joint for both sides!👌👌
required nearside - £39 posted. also got a offside one for £28 posted. not sure why the driver sides ones are far cheaper?. . .
bavs83 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bavs83 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2017 at 11:07am
http://www.npoc.co.uk/forum/breaking-primeras_forum89.html?SID=1a5b034c564268z1ee6c1da7243594631597222
Post Options Post Options   Thanks (0) Thanks(0)   Quote ahmed bossman Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2017 at 11:19am
lmaooo, im not a premium member, thats why i hadn't come accross the thread😂😂
nw,
Post Options Post Options   Thanks (0) Thanks(0)   Quote ahmed bossman Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2017 at 12:02pm
just ordered a CV boot kit for both sides aswell nowNorm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ahmed bossman Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2017 at 4:05pm
Lower control arms arrived today. just awaiting CV boots. then a weekend full of joysLOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote ahmed bossman Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2017 at 9:20am
CV boots arrives saturday morning at 7. woke up by mister postman banging on the door LOL
well weekend did not go as planned. got woken up nice and early to tackle all the things bar the Cat.
started with the lower control arm. removed all the bolts but the ball joint bolt. when i got to the ball joint i reallised its upwards  facing so its not something i could put a socket around without removing the hub. went out to get a comprehensive Clarke Pro spanner set including all sizes from 6mm to 30mm and then 32mm (no 31mm...). let it soak in GT85 (wd40) whilst i was out.
even when doubling up the spanners i could not get enough leverage to get the nut to budge. then let it soak again and went out to get a socket to remove the hub nut if thats what its called to remove the hub. bought 2 comprehensive 72t ratchet socket sets 3/8th and also a 1/2 inch set 5mm - 32mm (again missing only 31mm).   got back to relalisez the nut was actually bigger than 32mm.
 i went back to the Haynes manual i have and in there it does not mention the nut size. is anyone able to confirm with me the nut size for the the bolt?
i know it sounds stupid, i would have needed to remove the hub anyway to replace the cv boot but for some reason my mind didnt click!
Post Options Post Options   Thanks (0) Thanks(0)   Quote p11primeragt Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2017 at 10:05am
36mm hub nut.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ahmed bossman Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2017 at 12:09pm
thanks, ordered now.
is there anything else i should knnow when removing the hub etc? or anything else i would need (weny specific toold or anything/)
thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote p11primeragt Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2017 at 12:30pm
Hub or hub nut? Just get a length of piping over the breaker bar if it's 1/2 in or you'll be struggling no need if it's a 3/4 breaker bar as that will do it no probs.Get somebody to hold it on the brakes if the brakes are already off then put the wheel back on and put the socket through the centre cap.
