  New Posts New Posts RSS Feed - Nissan Primera P11 heat blower
hamherder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hamherder Quote  Post ReplyReply Direct Link To This Post Topic: Nissan Primera P11 heat blower
    Posted: 27 Nov 2017 at 2:52pm
Hello can you help me my blower  stop today, can not start on level 1 2 3 only on number 4
Thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote p11primeragt Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2017 at 5:08pm
You need a new heater resistor card.When mine went it was just like you say,only worked on number 4.
Post Options Post Options   Thanks (1) Thanks(1)   Quote p11primeragt Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2017 at 5:10pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote hamherder Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2017 at 5:34pm
THANK YOU i ordre new one today hope this will fix the problem.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote hamherder Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2017 at 3:51pm
Thumbs Up Work perfekt THANKS
chickp72 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chickp72 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2017 at 11:33pm
Hi, can I ask where you bought new card from?  I also need one and when I phoned Nissan last week they advised that part is no longer being manufactured.....Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote p11primeragt Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2017 at 1:53am
You can get them from ebay.
Retired.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chickp72 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2017 at 10:18pm
Nissan Part number is 271502F901 and haven't been able to find any on ebay.   Do you know if any of the other part numbers, which appear to be more commonly available on ebay, can be used? i.e. 271501N760?
Post Options Post Options   Thanks (0) Thanks(0)   Quote imckay Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2018 at 11:01am
The 271501N760 on Ebay look like a Chinese made version of the Resistor.
The all say suitable for the Primera. If not, you could send it back.
There is a 271502F900 available for 5 times the Price.
The 271502F901 you are searching for is exactly the same item but a newer revision.
It is a pretty simple device that usually fails due to corrosion from unavoidable moisture.
Personally, I would give the Chinese one a go.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chickp72 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2018 at 11:15pm
Thanks for the link imckay, very handy
