  New Posts New Posts RSS Feed - Nissan Primera P11 loud click from front end
dilrukds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dilrukds Quote  Post ReplyReply Direct Link To This Post Topic: Nissan Primera P11 loud click from front end
    Posted: 22 Sep 2017 at 4:45am
There is a single loud click from front end of my P11 when braking and accelerating back. (Feels like its coming from the driver side wheel or directly under the drivers feet) It also happens sometimes when hitting a pot hole. I've been trying to isolate this to the source for some time and haven't been successful.Confused
Any leads will be appreciated. Also I'm pretty sure this has nothing to do with brakes since a full overhaul was done recently.
naughtynorm View Drop Down
Mr Wannabe
Post Options Post Options   Thanks (0) Thanks(0)   Quote naughtynorm Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2017 at 12:09pm
Does it do it on full lock too ? If so could be a CV joint . Does it happen going over speed bumps or potholes as well ?
R.I.P The Wannabe .
www.twistedmindphotography.co.uk
Post Options Post Options   Thanks (0) Thanks(0)   Quote dilrukds Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2018 at 5:14pm
Not happening on full lock. Definitely not CV joints. But ya sometimes it happens on potholes.
bavs83 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bavs83 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2018 at 6:39pm
Start with the simple things. See if wheel nuts are tight, then the centre nut. Then work around with other components. May be a simple thing.
Its not what you drive....Its about how you drive it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote dilrukds Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2018 at 2:16am
Checked all that. Being having this for about 6 months now
Mr Wannabe
Post Options Post Options   Thanks (0) Thanks(0)   Quote naughtynorm Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2018 at 9:56am
Does it do it if jacked up and moved by hand ?
R.I.P The Wannabe .
Post Options Post Options   Thanks (0) Thanks(0)   Quote p11primeragt Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2018 at 10:49pm
You thinking top link Andy.
Retired.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dilrukds Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2018 at 3:01am
All the links were replaced. Shocks were replaced too. Only things that were not replaced are the coil springs and the rubber mounts on the strut tower. I think the springs have no life left in them and planning to go with coilovers soon. It's driving me nuts when moving in stop and go traffic Cry
Sut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sut Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2018 at 11:35am
Engine mounts maybe
Post Options Post Options   Thanks (0) Thanks(0)   Quote p11primeragt Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2018 at 3:35pm
I've had the same ,it comes and goes.Mine is due to the top door minge being worn.What happens is when you brake/accel the body flexes and hence the noise.
Retired.
