Nissan Primera P11-144 handbrake problem |
Post Reply | Page 12> |
Dawek
NPOC Guest Joined: 26 Aug 2016 Location: Czech Republic Online Status: Points: 114 |
Posted: 03 Sep 2017 at 12:14pm |
Hey guys, the problem is that when I pull the handbrake (about 8 clicks) and jack up the car I am still able to rotate the driver side wheel (not as easy as when the hanbrake isn't pulled).
Any ideas how to repair it?
Either the handbrake mech is in need of repair ie new or rebuild caliper or it's the cable that's stretched or partly seized going to it.Ideally it should be adjusted so the wheels slightly drag on the first click.
A lot of times you can work the caliper by the handbrake after cleaning it up and using some oil down the pivot area.
Dawek
So that means I need to unmount the caliper, right?
Is it an easy process?
Not needed if you want to try and free it up first,just oil it after cleaning around the spring area and work the handbrake a few times then repeat.Then check to see if the handbrake holds that wheel better than it was,the handbrake should feel better too.
Dawek
Ok, that sounds better :D
What oil do you recommend to use?
wd40 it first then after you have worked the handbrake a few times drop add a bit of 3 in 1 oil to it.
Dawek
Thanks, but unfortunately we don't have 3in1 oil in my country, so i suppose any multi-purpose oil should be fine, right?
Yes
dutch-pete
NPOC Guest Joined: 30 Jun 2009 Location: Other Online Status: Points: 3 |
Looks like it is the piston. Happened 4 years ago for the first time. It is a APK (MOT) failure so I did the same, WD40 WD40 WD40 (or any penetrating oil). It will work again for a couple of weeks and after a year before the MOT the same procedure. Always cheaper then changing the whole brake piston.
dutch-pete
