  New Posts New Posts RSS Feed - Nissan Primera P11-144 oil leak
Dawek View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dawek Quote  Post ReplyReply Direct Link To This Post Topic: Nissan Primera P11-144 oil leak
    Posted: 24 May 2017 at 10:24pm
Hey guys,
I did a quick check of fluids under the hood and an unpleasant surprise struck my eyes. My beloved SR20 is leaking oil (sorry for the photo quality, as it is dark outside i had to use flash). It looks like a rocker cover gasket is leaking, but i don't know, it is new to me. Any ideas how to fix that?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dawek Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2017 at 10:30pm
Forgot to add the photos :D
Post Options Post Options   Thanks (0) Thanks(0)   Quote p11primeragt Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2017 at 10:32pm
Can only be either the rocker cover gasket or it's the o ring on the distributor shaft.Most likely the latter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dawek Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2017 at 11:01pm
Ok, thanks, I'll check tomorrow with better lighting to see where it looks to be coming from. Is changing the o-ring an easy fix, or is some deeper disassembly needed?
Post Options Post Options   Thanks (1) Thanks(1)   Quote p11primeragt Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2017 at 11:31pm
Just the 2 x 12mm bolts to undo plus the connector and then take the distributor out from the camshaft slot.Mark the position of the distributor before you remove it by scribing a mark on it and the engine.Put the distributor back making sure marks line up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dawek Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2017 at 11:47pm
Ok, sounds quite simple. Should i drain the oil first? (as it is leaking, there might be some oil up there, right?) And is that some sort of special o-ring, or should i gram just any o-ring of the same size from hardware store?
Post Options Post Options   Thanks (0) Thanks(0)   Quote p11primeragt Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2017 at 11:57pm
No need to drain oil,just let the engine sit for a while before hand,a small amount of oil will still dibble out so be prepared for it.
The o ring is Nissan only.It's thicker compared to normal o rings. Although you may try one if you wish.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dawek Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2017 at 9:29am
Thanks. I'll ask at nearby Nissan dealership, if they'd be able to provide me with one.
