  New Posts New Posts RSS Feed - Nissan Primera P11-144 power steering/maf sensor.
150primera View Drop Down
Non Member
Non Member
Post Options Post Options   Thanks (0) Thanks(0)   Quote 150primera Quote  Post ReplyReply Direct Link To This Post Topic: Nissan Primera P11-144 power steering/maf sensor.
    Posted: 05 Feb 2012 at 11:19am
Hello people...just wondered if i can use brake fluid to top up the power steering reservior. Also,can someone confirm that the 1.8 maf will definately work in the 2.0 engine as i intend to get a genuine Bosch one from Eurocarparts....cant understand the massive price difference between the two at allConfused
2.0 Sport...Apexi filter located in wing...SS Autochrome header.
Answer Answer
Post Options Post Options   Thanks (0) Thanks(0)   Quote imckay Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 11:48am
You need dexron iii auto transmissin fluid for the power steering. Not the same as brake fluid.
The 1.8 MAF will work on the 2.0. Just use the sensor. You will need a security torx driver to remove it.
Much cheaper because an exchange is not offered on the 2.0
Non Member
Non Member
Post Options Post Options   Thanks (0) Thanks(0)   Quote 150primera Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 12:01pm
The price for the 1.8 without the exchange is still a lot less than the 2.0 though.
Non Member
Non Member
Post Options Post Options   Thanks (0) Thanks(0)   Quote 150primera Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 12:03pm
There must be a difference between the two surely.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote imckay Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 1:10pm
They may be different but the 1.8 sensor works in the 2.0. There are plenty of people using them with no problems.
£318 vs £58.
Non Member
Non Member
Post Options Post Options   Thanks (0) Thanks(0)   Quote 150primera Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 7:22pm
I have a suspision that the 1.8 mafs are reconditioned and the 2.0 ones are brand new.....hence the exchange facility and price difference with the 1.8 s.A 1.8 it is then.Got an ebay copy on at the minute........sometimes the car runs great,other times it runs as if ive got the handbrake on !
crazy taxi View Drop Down
Non Member
Non Member
Post Options Post Options   Thanks (0) Thanks(0)   Quote crazy taxi Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 9:40pm
A faulty MAF normally shows itself by a very uneven idle and heavy fuel use and soon throws the EML on.
I've got the 1.8 maf on my 2.0 and the only difference between the two is the size of the maf body. The fact that they offer an exchange on them shows they must refurb them, never been able to understand why they can't refurb the 2.0 one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote imckay Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 9:43pm
For £58 they are reconditioned. Plenty fitted and I can't remember anyone reporting an early failure after fitting one.
This type of Bosch hot film MAF fitted to lots of car makes does seem to have a life of 70-100K miles.
I suspect that Bosch recondition by either changing the whole sensor or the hot-film part that wears out.
Ebay MAFs are very hit and miss.
Copyright (c) 2001-2012 Nissan Primera Owners Club. All rights reserved.
