Nissan Primera P11-144 reverse light switch |
mestala
NPOC Guest Joined: 15 Jan 2012 Location: Bulgaria Online Status: Points: 34 |
Posted: 15 Jan 2014 at 6:17am |
Hi all
My other half saw that the reverse lights were not working the other day.Bulbs look ok,so was wondering if it could be the reverse switch.Anyone"I'm sure there is",know where it is situated,I ask this as on a car I had many moons ago it was the switch that was duff....or could it be something else. Thanks Steve
The reverse sensor switch is located on the gearbox towards the bottom,the sensor threads into the gearbox,so you would need to drain the oil first if you need to remove it and test it etc.
Then use some teflon tape on the threads when putting the sensor back into the gearbox to make sure it does not leak. |
imckay
Are you sure it is not the bulb? There is only one reverse light on the UK P11-144. Don't know if the Euro is the same?
mestala
Thanks for your replies guys,I'll check the bulb,or bulbs first,"again",and to see if power is getting to the R/L unit.
Cheers Steve
skydiver
NPOC Member Joined: 26 Jul 2011 Location: Surrey / Sofia Online Status: Points: 913 |
Are you from/in Bulgaria, Steve?
If so, we can arrange someone from our big cities to meet you and help you with that. Maybe the issue is only with the connector ?
Primera x3
redshark1
NPOC Guest Joined: 31 Mar 2007 Location: Yorkshire (West) Online Status: Points: 1826 |
I'm willing to fly out with the tape.
See my Nissan Primera P11-144 common faults and fixes guide:
Nissan p11 144
NPOC Guest Joined: 08 Apr 2018 Location: Denmark Online Status: Points: 45 |
Did you fix the light? I am having the same problem😬🤔
