Nissan Primera P11-144 Suspension Noise |
alvin_roy
NPOC Guest Joined: 05 Dec 2009 Location: Mauritius Online Status: Points: 32 |
Posted: 05 Jul 2016 at 9:20am |
Hi!
I have a 2001 P11-144. Since some time, there are noises in the suspension especially when you run into pot holes or go over speed bump. Which parts should be changed to fix the issue? (Arm, CV Joint, Roll bar,.....) Please advise. |
prim-n-proper
NPOC Guest Tick Tock Tick Joined: 28 May 2007 Location: oop north Online Status: Points: 18737 |
depends on the noise really, squeaking = top arms, knocking = usually just ARB drop links
COTM: MAY 2006 P11 GT
COTM: MAY 2009 P11 SLX+ COTM: AUG 2012 P11 WAGON LAST EVER COTM: NOV 2013 P10 eGT Your "other car" might be newer, but it don't make it better than a P chassis.*PNP17* |
alvin_roy
Hi!
There is very little squeaking but a lot of knocking especially on bad roads. Thanks. |
Alvin Roy
alvin_roy
Dear all!
About the front suspension knocks, the mechanic has advised to have the rack ends left/right changed. Can someone please post a photo of this part? Thanks!! |
Alvin Roy
