  New Posts New Posts RSS Feed - Nissan Primera P12 04 Key Fob Problem
rabies View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rabies Quote  Post ReplyReply Direct Link To This Post Topic: Nissan Primera P12 04 Key Fob Problem
    Posted: 01 Sep 2010 at 2:53pm
Hi, Yesterday morning I went to open my car to go to work. Pressed the unlock key but nothing happened. Went and got my second key - but could not get the car to open.
I did previously had a problem with a loose main car battery terminal (after work in Nissaan Garage) and I thought that it was the cause of the problem, but I could not get into the car to check it.
(I remembered something about access thru the passanger door - but manual was in glove box)
After about 15 minutes the main Fob eventually opened the car. I fully expected to have a main car battery problem - that the loose terminal issue had returned. But the car started first time and everthing seemed fine.
However this morning I had the same problem (but I thought I didn't lock the car last night)
Eventually I got the Key Fob to open the car after about 5 mins, by holding the fob directly over the bonnet.
At lunch hour I checked the Car again. It locked and unlocked from a distance of 15 feet. Anyway I have just purchased a replacement key fob battery and its working from 90 feet distance.
Hopefully the problem was just the fob battery (but its a little strange that the backup key was also not working - or is it)
Anyway I will follow up tomorrow with an update.
Anybody else with similar problems or and ideas?
Keep trying
fossyant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fossyant Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 7:51pm
Reprogram your keys - sometimes happens with one of my fobs..........(I have 4 though.. two spares just in case).....
Post Options Post Options   Thanks (0) Thanks(0)   Quote rabies Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2010 at 9:11am
Thanks Fossyant.
Same problem this morning. Key Fob would not open Car on first few attempts. Cry
But a lot quicker than the last two mornings.
Reprograming Keys - Is it easy to reprogram P12 (2004) keys?
I know I did it with my P11. Thought I read it was very difficult with P12 (hopefully thats not the case).
Keep trying
Post Options Post Options   Thanks (0) Thanks(0)   Quote rabies Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2010 at 9:21am
How do Keys get de-programmed?
I found this on another tread - presume it will work. Will try it this evening. Thanks
You can program a maximum of 4 P12 key fobs as follows:
Obtain all remote controls
Switch ignition ON and OFF 6 times within 10 seconds
After 2 seconds indicators will flash twice. Programming mode will be activated. Proceed as follows:
Press & hold unlock button
Press lock button 3 times
Release unlock button
Indicators will flash once to confirm correct programming
Repeat above procedure to program any remaining remote controls
After fourth key is programmed, indicators flash 3 times to confirm correct programming
Switch ignition ON
Indicators flash twice if 1-3 keys have been programmed
Indicators DO NOT flash if 4 keys have been programmed
Programming mode de-activated
Check operation of all programmed remote controls
Keep trying
Post Options Post Options   Thanks (0) Thanks(0)   Quote fossyant Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2010 at 8:58pm
Thats the one
norbert eggcup View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norbert eggcup Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2010 at 8:20pm
just to add to this i have programmed this type of key
to operate my central locking/alarm which came with this type of key
if i can get immoby code sorted ill get key cut
the spaceship and the P12
Copyright © 2001-2013 Nissan Primera Owners Club. All rights reserved.
