Nissan Primera P12 1.6 Check Engine Light |
Post Reply | Page 12> |
Storm Eye.
NPOC Guest Joined: 25 Sep 2014 Location: Ireland Online Status: Points: 17 |
Posted: 05 Feb 2015 at 3:18am |
Hi everyone as stated up above I have a Nissan Primera P12 1.6 Petrol and the engine light is staying on.
Any help would be greatly appreciated. Thanks in advance. |
Storm Eye
http://www.npoc.co.uk/forum/p12-all-engines-read-reset-ecu-fuel-pump_topic54932.html when you do it correctly just count the flashes of the light it will give a repeating sequence of four digits, 10 flashes representing zero |
Storm Eye.
Hi Timeshock. I have done exactly as it says:
Turn ignition on Wait 3 seconds Depress and release accelerator pedal 5 times in 5 seconds, then take foot of the pedal. Count seven seconds and then depress the accelerator pedal and hold it down for 10 seconds. As soon as the Eml starts flashing error codes, take foot of the pedal. I am not getting any engine management light flashing after 10 seconds. Do I keep my foot on the pedal until the light starts flashing regarding of the time? Many thank for your response.. 😀 |
Storm Eye
Storm Eye.
[QUOTE=Storm Eye.] Hi Timeshock. I have done exactly as it says:
Turn ignition on Wait 3 seconds Depress and release accelerator pedal 5 times in 5 seconds, then take foot of the pedal. Count seven seconds and then depress the accelerator pedal and hold it down for 10 seconds. As soon as the Eml starts flashing error codes, take foot of the pedal. I am not getting any engine management light flashing after 10 seconds. Do I keep my foot on the pedal until the light starts flashing regardless of the time? (Nothing happened after 10 seconds) Many thank for your response.. 😀 |
Storm Eye
sagarka
NPOC Guest Joined: 18 Jan 2015 Location: GERMANY Online Status: Points: 3 |
i have also the same problem i had check it same way but no luck n e body explain n e other option thanks in advanced
To the both of you, persevere, use a stop watch if you need to , If it does not work then you are going to have to pay to get the code read.
Storm Eye.
Thank you, will get stopwatch and try again.. 😃
Storm Eye
Storm Eye.
Hi Timeshock , thank you so much.. It worked with a stop watch. I got ten flashes then 3, and then ten flashes then 4. I am not quite sure what this means? Is the error 0304? Any help would be great. Thanks again for the help to date.
Storm Eye
Cylinder 4 Misfire, have you any symptoms?
Storm Eye.
When I start the engine it seems a bit rough for about 10 seconds and then goes out of it. I will look at the spark plug tomorrow no4 and replace and see if error comes back after clearing the error..
Storm Eye
