Nissan Primera P12 1.8 2004 hard to engage reverse |
Post Reply | Page 12> |
Nixwift
NPOC Guest Joined: 11 Aug 2016 Location: East Sussex Online Status: Points: 4 |
Posted: 11 Aug 2016 at 9:04pm |
I just bought my P12 today. Generally very happy with it, but I've now discovered that it is very difficult to engage reverse gear and the other gears are also quite sticky at low speed. However, it is easy to shift through all gears when the engine is off. I read a post on a forum that suggested this could point to a linkage problem. Does anyone have any thoughts/ suggestions on this and any idea how much it might cost to fix?!
Many thanks, |
If the gears are tight with the engine running but ok when the engine is not running that points to a clutch issue.
Agreed Park on an a hill and pull away in 2nd and see if revs rises and no progress |
Nixwift
Thanks for the quick replies guys. It actually pulls away ok in 2nd on a hill.
The forward gears aren't too bad. Reverse was ok initially this morning but got progressively worse as it warmed up. Also the parking sensor noise sometimes sticks in continuous when reversing, but I'm guessing that wouldn't be related? |
Electrolyte
NPOC Guest Joined: 12 Aug 2011 Location: Ba-Bru City Online Status: Points: 1368 |
Worth trying an oil change first.
If in doubt give it a clout!
Nixwift
Thanks everyone. Gonna get a new clutch.
aamier
NPOC Guest Joined: 22 Jul 2012 Online Status: Points: 260 |
any improvmnent with new clutch?
Nixwift
Yes, much better thanks. Had the clutch changed and fresh gear oil. Did the trick. Many thanks everyone, once again.
Nick |
chiz2
NPOC Guest Joined: 04 Nov 2014 Location: southport Online Status: Points: 13 |
if you dont mind me asking ..how much for a p12 clutch as mine is doing the same?
chiz
