Nissan Primera P12 1,8i Fault codes timing issue |
Orchid70
NPOC Guest Joined: 24 Feb 2018 Location: Sweden Online Status: Points: 5 |
Posted: 17 Apr 2018 at 7:19pm |
P12
1,8i 2002 211000 KM Check Engine light on Fault codes: P0011 P0340 - Timing too early bank 1 That would be that the chain is too long, right? There are also fault codes for the catalytic converter, both banks: P0420 - Effect below threshold value bank 1 P0430 - Effect below threshold value bank 2 MIL comes on faster and faster after eraising the fault codes. Both catalytic converters should be changed, right? Or is there a change it would be both lambda sensors? Thank you!
It has been said a lot on here that the 1.8 is susceptible to a stretched chain. Do you have much rattle on a cold start?
Orchid70
Will check that - the car is not here at the moment.
Thanks! |
