  New Posts New Posts RSS Feed - Nissan Primera P12 2.2dCi 2002 Battery Draining
Phil_L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil_L Quote  Post ReplyReply Direct Link To This Post Topic: Nissan Primera P12 2.2dCi 2002 Battery Draining
    Posted: 06 Jan 2019 at 10:44am
Hi I have a Nissan Primera P12 2.2dCi 2002 which is draining the battery if left for more than two days.  The vehiicle is fine if used every day.
I have tracked it down to fuse 12 in the fuse box under the stearing wheel.  Unfortunately theree are a number of items connected to this which are buried in the dashboard.  Does anyone know of any of the devices here which can cause this problem?
Many Thanks
Phil
Post Options Post Options   Thanks (0) Thanks(0)   Quote timeshock! Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2019 at 11:53am
Sounds like your trunk room light check your boot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil_L Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2019 at 4:17pm
I have checked the boot light.  It goes out when the boot is closed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote timeshock! Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2019 at 4:54pm
Why do you think it is fuse 12? as well as a number of things that run off it the Nissan Anti theft system is on this so will be live
Estyfort View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Estyfort Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2019 at 5:13pm
Check too the defogger relay.
