  New Posts New Posts RSS Feed - Nissan Primera P12 2.2DCi power loss
rsjon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rsjon Quote  Post ReplyReply Direct Link To This Post Topic: Nissan Primera P12 2.2DCi power loss
    Posted: 11 Jul 2011 at 3:31pm
My Primera has an occasional fault in that sometimes it loses power and will only accelerate slowly (like it is in 5th gear at 25mph). The MIL light is not on and no fault codes are logged.
If I stop the car and turn off the engine, then restart, the fault is gone (for a while!).
I have looked through some posts here but nothing I could find quite matches this.
I don't know when the fuel filter was last changed...is this a possibility?
What about the dreaded suction valve? (not sure what it is actually!).
Any thoughts?
Thanks,
Jon. Confused
ernehale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ernehale Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2011 at 5:23pm
Unfortunately it could be a host of things. Try a ecu/pump reset for starters info below the it could be list.
It could be a: -
blocked fuel filter
carboned up injectors ( A quality injector fuel line cleaner in the fuel may do the trick)
engine transmission earth strap fault
failing suction control valve
low pressure on the common rail feeding the injectors.
MAF fault (Try cleaning the MAF with carburretor or electrical contact cleaner.)
EGR Exhaust gas recirculating valve fault.
Nissan YD22/25 ECU and Fuel Pump Reset/Re-learn Procedure
To carry out the reset carry out the following.
Turn ignition on so all dash lights come on.
Wait 3 seconds PUMP accelerator pedal 5 times within 5 seconds....
With foot now OFF accelerator wait 7 seconds.
After 7 seconds press and hold down accelerator pedal for 10 seconds.
After 10 seconds the Engine Management Light will start to flash, at this point remove foot from accelerator. The Nav is now in diagnostic mode, so let the EML flash for a bit. the press and hold the accelerator pedal down for more than 10 seconds..this will then reset ECU and fuel pump etc......and put them into learning mode.
NOTE: When the EML light is flashing, this is listing possible fault codes... so if you know how to read the fault codes or know the sequences then you can figure out any possible faults with your Nav without getting the dealer to do it!!
thanharossi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thanharossi Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2011 at 1:42pm
Hi RSJohn. I actually experienced this problem yesterday and had to pull over and restart the car. I have had this on a few occasion where I accelerate and then I lose power and them take my foot off the accelerator and when I put my foot down again, then it would be fine. But yesterday was the first time I actually needed to pull over and restart the car for the problem to stop. Did you manage to find anything more on this or have you tried what Ernehale suggested?
Many thanks
AdamH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AdamH Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2011 at 7:25pm
rsjon - I have this problem - mine is fine, until it sits at idle for much over 1 minute, it then loses power when you drive off. It is most likely your engine going into "limp home mode". I never had any lights come on the dash when it happened. My local garage (independant - not a Nissan dealer) plugged in the fault code reader and the one that came up suggested Suction Control valve, which is a common problem on ther P12. The part is around £130 from Nissan. It is being fitted tomorrow - I dont think it is that big a job, a few guys on here have fitted the part themselves, but it is beyond my capabilities. I will let you know if it works. Also worth mentioning you apparently do not have to have Nissan reset the electrics when the new part is fitted - the ECU reset above will do the same thing - will update, hopefully tomorrow night with a bit of luck!
2004 P12 2.2 Dci SVE
Post Options Post Options   Thanks (0) Thanks(0)   Quote thanharossi Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2011 at 5:25pm
Hi Adam. Hope this works for you mate. Mine does not happen after sitting at idle but it may just beit has not gotten that bad yet. Good luck. Please keep us posted.
farahgandhi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farahgandhi Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2011 at 7:46pm
Hi Adam, I am having a similar problem - can you tell me if the problem was sorted after replacing Suction Valve??
102cars View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 102cars Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2011 at 10:16pm
See tonight's new thread P12 DCI loss of power, hope this helps
2004 Primera 2.2dci S Wagon. Loves simple cars like 2CVs. Changes cars a lot, Primera is number 102...
wellman69 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wellman69 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2013 at 8:15am
Nissan primera 2.2 diesel poor power on take off
Hello everyone. i had my p12 05 plate changed clutch, dual mass flywheel and gearbox just two days ago. Now the car lacks its usual engine power on take-off. The turbo whistling can not be heard anymore. it feels a different car completely. the car is the [s] type.
Can anyone help me please?
Many thanks
wellman
tony101 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tony101 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2015 at 6:14am
i have a nissan primira 2004 se 2.2diesel.my turbo went on the car and i had it fixed.i put it back changed the oild filter,changed the oil,new air filter and fuel filter.I cleaned everything out including intercooler and cleaned the egr out.Istarted the engine the revs picked up but when i put my foot down after 2000 revs im still getting a lot of black smoke.i took it around the block as soon as i put it in gear there is no power in the car at all im only getting just over 1000 revs and a lot of black smoke.can anybody help
mattsix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mattsix Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2015 at 7:54am
Sounds like the turbo is not spooling up.
Recheck all of your pipe work and check for cracks/splits etc.
