Nissan Primera P12 Air Bag Warning Light |
Post Reply | Page 12> |
brian_magicbus
NPOC Guest Joined: 24 Jan 2012 Location: Dublin Ireland Online Status: Points: 15 |
Posted: 11 May 2012 at 10:55am |
Hi, Please Help, I have a 2005 P12 2.2 D. last week I pushed the front passanger seat forward to fit stuff in the back, I heard a click under the seat, when I went to drive away, the air bag light was flashing on the dash. when I got home I looked under the seat. The big yellow connector block was pulled apart so I clicked it closed, but the air bag warning light is still flashing.
How do I fix it.
Thanks.
Brian.
Thanks(2)
turn the key to on (not starting the engine)
the airbag light will be on for 7 seconds, as soon as it goes out turn the key to off wait 3 seconds repeat twice more turn to on the airbag light will flash in sequence (a code showing fault you may not havit one now) Start engine and turn to off switch on and fault should be cleared
brian_magicbus
Thank You very much for taking the time to answer my question, I'll give it a go.Brian.
Thanks(1)
Brian, see the edited post above, sorry I missed out the 3 second rule
brian_magicbus
Thank's again, I'll give it ago, let you know how I get on.
brian_magicbus
Your fantastic!!!! I did it, air bag light gone off,,, thank You so much.
Brian
brian_magicbus
I did it, thank you so much, air bag light gone off.
Kind Regards Brian.
Thanks(1)
Simples when you knows how
Immlang
NPOC Guest Joined: 10 Jan 2011 Location: Brigg Online Status: Points: 1 |
Thank you so much for your advice.
I had this problem, I followed your advice and the fault cleared. I am very grateful.
Alan 114
NPOC Guest Joined: 13 Oct 2013 Online Status: Points: 1 |
Thank you thank you thank you just tried it on my car yes it worked thought i was going to have to get it reset at the garage . so Big Thanks Alan
