Nissan Primera P12 - Check Engine Light ON |
Post Reply | Page <12345 7> |
gazandsue58
NPOC Guest Joined: 09 Feb 2013 Location: Staffordshire Online Status: Points: 1668 |
I changed the crankshaft sensor and it was the same the way we fixed it was to re do the earth from the battery to the transmission and one from the battery to the inner wing instead of the one complete to wing then to transmission.
iasad1
NPOC Guest Joined: 16 May 2014 Location: London Online Status: Points: 7 |
Got a call from the mechanic, he said after he test drove for a bit , the engine was still misfiring a bit. He suggested changing the coil pack.
iasad1
Right, changed one of the coil packs but random misfire still exists. Today the ECU threw P0300, which I believe is a random misfire and could be anything. My gut feeling is it could be one more coil pack
The mechanic I am dealing with is super confused and is doing things randomly so I have ditched him for the time being and taken things in my own hand. Anyway, one more random thing is that misfire is happening most of the time I re-fuel, so another long shot guess is fuel injector or pump. Your thoughts??
roobarbthedog
NPOC Guest Joined: 16 Jun 2009 Online Status: Points: 24 |
I hope you don't have the same problem I had. Mis-fire eventually diagnosed as low compression in cylinder 4. Engine was shaking and obviously mis-firing. Car has been in the garage now for 6 months! After getting the cylinder head rebuilt, new valves and seals the car has "developed" an electrical fault and will not fire. See thread:
Latest on this is it "might" be an issue with the immobiliser, although none of the dashboard icons or fault codes were reporting anything.
About to phone again and see what the story is.
Cheers
Roobarb
iasad1
All I had to do was to change 1 more coil pack. Car is running as good as new. Fingers crossed it stays that way.
gazandsue58
Glad you got your Car sorted before the bank holiday weekend.
mcgangsta
NPOC Guest Joined: 19 Apr 2012 Location: Vantaa, Finland Online Status: Points: 60 |
Damn, I've not been around for a year or something, but I had this similar problem with 2003 P12 also. Just changed one of the coil packs and it was good to go. But it was very confusing, they couldn't find anything @ garage so I asked them to test drive it. After that they found the faulty one and changed it. If I've just known the problem... much cheaper to change them yourself =) Glad to hear it's working now though.
iasad1
Thanks Gangsta. I know! the mechanic I was dealing with was purely guessing, causing so much more frustration.
Next time, I will diagnose things myself, buy the part myself and just ask him to change it. Thanks everyone for the support. |
j6k4
NPOC Guest Joined: 30 May 2014 Online Status: Points: 1 |
Hello,
Nissan Primera 1.8 P12 Petrol Here Recently the engine was swapped for a different one (80k) at a local garage as the original engine broke The car drives perfectly fine but the engine light came up and in the info section it says that a malfunction might have happened to the engine and that I should not drive at high speeds and go and get it checked at Nissan dealer as soon as possible. - something I'd rather not do as they charge insane money and also because I have already spent over 1k on this car in the last 9 months or so just for repairs and this car is probably not even worth £1k but I just love it and dont wanna give it up. so this is why im here hoping u could give me a clue on these flashing codes. Can you please help me with the diagnosis codes? Would be greatly appreciated if you know what these are about. Many thanks The engine light flashes as following 10 - 1 - 5 - 4 10 - 1 - 5 - 2 10 - 1 - 5 - 8 I'm new on here so please have some patience with me, thanks in advance and keep up the good work
They are all codes relating to the oxygen sensors, check that the air intake is not blocked, check the air filter, check for leaks/splits in the hoses and damage to the exhaust/manifold
