  New Posts New Posts RSS Feed - Nissan Primera P12 Dashboard Lights problem
panichri View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote panichri Quote  Post ReplyReply Direct Link To This Post Topic: Nissan Primera P12 Dashboard Lights problem
    Posted: 15 Feb 2010 at 6:49pm
I have a Nissan Primera P12 Saloon 07/2002.
My dashboard lights keep going on and off whilst driving or when stopped.
when they go off the speedometer stays at the speed i was going and the odometer the same. I have no display within the car at all. Indicator/handbrake lights dont go on. Nothing works except the radio.
I've been to Nissan electrician and he changed the immobiliser (whatever that is) for 400 euros, but nothing, still the same. He now changed all the instruments on the dash board ( speedometer + odometer) and again nothing. Its costing me a fortune and i am under the impression he doesn't know how to fix it, so thats why i'm here. hope someone can help me.
norbert eggcup View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norbert eggcup Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2010 at 10:46pm
check all the fuses
the spaceship and the P12
Post Options Post Options   Thanks (0) Thanks(0)   Quote panichri Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2010 at 6:29am
Originally posted by norbert eggcup norbert eggcup wrote:
check all the fuses
Thanks for your info, will check and get back with the results.
Post Options Post Options   Thanks (0) Thanks(0)   Quote panichri Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2010 at 2:52pm
check all the fuses
All fuses are ok. No problem there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote imckay Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2010 at 7:09pm
Is it the same fault as this? http://www.npoc.co.uk/forum/topic30636.html
Post Options Post Options   Thanks (0) Thanks(0)   Quote panichri Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2010 at 10:33am
Thank you for your reply, I have exactly the same problem as he does, but can you tell me which one fuse 12 is, as I have no idea.
As you open the bonnet the fuses are towards the right side, behind the radiator near the battery. All of them are ok, but they dont have numbers?
If you can please advise me, i would be grateful to you.
Thanks again
Post Options Post Options   Thanks (0) Thanks(0)   Quote panichri Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2010 at 7:35pm
Thanks again
Thanks got it to work perfectly.
Mezool1000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mezool1000 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2013 at 12:41pm
Hi Sorry to drag up an old post - but can you tell me where fuse 12 is? is it under the dash board or in the fuses by the steering wheel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mezool1000 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2013 at 12:43pm
[QUOTE=Mezool1000]Hi Sorry to drag up an old post - but can you tell me where fuse 12 is? is it under the bonnet or in the fuses by the steering wheel - as I cant seem to get my Odomter to display anything - all other electrics are fine
Electrolyte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Electrolyte Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2013 at 3:09pm
Should be in the fuse box at your right knee , centre row nearest to steering wheel.
If in doubt give it a clout!
