Nissan Primera P12 - Display issue |
Shiroan Cader
NPOC Guest Joined: 28 Jun 2018 Online Status: Points: 3 |
Posted: 28 Jun 2018 at 4:03pm |
I have nissan primera p12 2001, 2000cc Japan used imported car. Since past 3 months display get stuck in morning. Until do power reset it was stuck/freeze. My car display is not coloured one, just one colour. 1. Can you assist for above issue. 2. Is that display possible to swap with colour type 3. What Is the possibility to add reverse camera/DVD for colour type display Thanks. |
Hi and welcome to the forum. Japanese imports have some fundamental differences to the euro model, as far as swapping out components or upgrading is concerned it is a minefield even without it being a non euro model. I’m not sure I have heard of a screen freezing in this way before, you may want to have a look on the New Zealand NPOC site as they all have import models. Swapping to a colour screen I believe would require other upgrades so I would try to source an exact swap. Camera upgrade would require a colour screen and the wiring loom to be fitted, posts on here have been hit and miss to whether they are fitted or not.
imckay
Welcome to NPOC
It might be worth unplugging and replugging the connectors to the Audio and Display. Possibly a loose or corroded connection.
Shiroan Cader
Ok thanks for the prompt feedbacks,
I will try so. |
