nissan primera P12 drivers door wont lock |
Post Reply | Page <1234> |
I can not understand the downloading problem you are having if you are using a PC, is the OS Windows.
I have just tried it again and it is fine, 97mb download, just make sure you hit the green download button in the box with the title of the zip file in it then accept the download that windows throws at you at the bottom of the screen, I usually set a specific download location with the drop down menu
Snakebite
NPOC Guest Joined: 28 Aug 2013 Location: West Yorkshire Online Status: Points: 19 |
I'd have taken off the door card, sat in the car and worked the locking mechanism, then you'd be able to see what was happening, it might be that you just have a connector rod disslocated...
Defo not the connector rods/strap, it can be opened and closed manually on both outer and inner handles
Snakebite
Does it lock properly with the key?
As mentioned above when inserted down the open edge of the door through the slot it does, don't forget there is no barrel lock on the drivers side
Snakebite
Oh, didn't realise you didn't have a barrel, I thought they all had a barrel on the drivers door... lol.
ragt20
all P12, N16s and K12s no drivers side door barrel from what I remember
dragonlord
NPOC Guest Joined: 27 Dec 2009 Location: Dorset Online Status: Points: 53 |
waiting for my part to arrive now and hoping it's the correct part etc. looking forward to having a go at fitting it myself.
I eventually managed to get hold of the electronic manual so that's a good start. at least I can see where all the door screws and plastic clips are. Thanks to everyone for the advice on this subject. I will keep you all posted when I have fitted the part, which hopefully will be this weekend. Only problem is, I might have to miss the Bournemouth Air show. That's a bummer!!
This site is great and everyone is sooooo helpful. Thanks Guys & Gals
Noooo, don't miss the airshow
sgf
NPOC Guest Joined: 15 Dec 2014 Online Status: Points: 2 |
Hi
Thought I would answer an old question posted on how to remove a drivers side door handle on a P12. Once all the panels are off and glass removed- 1. Loosen the torx screw located just above the 3 securing screws of the locking mechanism. 2. Push the plastic handle mechanism into the door, it only moves a bit. 3. Pull the outside handle out, like you would open the door and then remove the end plate, this was stiff but came out with a push from the inside of the door pushing outwards. 4. Once the plug is removed you can prize the handle backwards and it all comes apart. 5. This allows you to remove the cable to fit a new actuator and mechanism. Took me ages to work this out, so I hope this helps everyone on the future. |
