nissan primera P12 drivers door wont lock |
Post Reply | Page <1234> |
cxyra
NPOC Guest Joined: 30 Nov 2010 Online Status: Points: 269 |
Why did you change the actuator ?
sgf
NPOC Guest Joined: 15 Dec 2014 Online Status: Points: 2 |
We had an intermittent fault locking and unlocking, this cured the issue.
power of mad
NPOC Guest Joined: 25 Oct 2014 Location: Lietuva Online Status: Points: 46 |
Similar problem.
Noticed today because I needed to disconect battery and wanted to lock driver doors. No idea how long this problem persisted. So, all other doors are locking/unlocking just fine except Driver doors. Things I tried: *Lock unlock with keyfob many times *Lock with inside button then try to open from open window, it opens. Doors clicks like its locked/unlocked but it isnt locked. Any suggestions? |
Check the physical connection between the lock and the acctuator
power of mad
I should tear down interior panel and glass in order to do that, right? |
I afraid so, I recommend you download the free electronic service manual following the link below, see page BL-111
http://www.npoc.co.uk/forum/nissan-primera-factory-service-manuals_topic29493.html |
power of mad
Thanks for help, I'll look into it!
power of mad
To add up, I cant lock driver doors in both automatically (keyfob, button inside) and manually with key
Yeah sound like a mechanical issue
power of mad
I haven`t opened anything on my doors yet but I`m thinking if I can fix the problem myself (minor problem) or just buy whole lock part.
