Nissan Primera P12 electrical problem |
Pauly
NPOC Guest Joined: 23 Apr 2018 Location: New Zealand Online Status: Points: 13 |
Posted: 05 Nov 2018 at 1:58am |
Not very PC literate buy will try to explain my issue as well as attach a picture.
Basically I have reloomed a P12 petrol wagon with the qr20 motor everything works perfectly except drivers window because I have no idea how the last bit of wiring should be attached. Please help |
Pauly
Pauly
https://ibb.co/kMeTQ0
Pauly
Cant upload pic
essNchill
I recommend you download the free electronic service manual following the link below |
Pauly
Done that already, couldnt find relevant info regarding colour codes or connection
The likelihood is yours is a Japanese import and different form the European Models, However if you look on page GW74 you will see a diagram which show the wires peeling off the main loom to a connector terminal which in turn connects to the other connector which the wires disappear into the door. The wire colours are shown on all the diagrams eg GW-62 etc Hopefully you will be able to work out which joins to which
Pauly
Thankyou for your help mate, it us a map import, I'll give it a crack after work.
