  New Posts New Posts RSS Feed - Nissan Primera P12 electrical problem
Pauly View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pauly Quote  Post ReplyReply Direct Link To This Post Topic: Nissan Primera P12 electrical problem
    Posted: 05 Nov 2018 at 1:58am
Not very PC literate buy will try to explain my issue as well as attach a picture.
Basically I have reloomed a P12 petrol wagon with the qr20 motor everything works perfectly except drivers window because I have no idea how the last bit of wiring should be attached. Please help
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pauly Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2018 at 1:59am
https://ibb.co/kMeTQ0
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pauly Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2018 at 2:04am
Cant upload pic
Post Options Post Options   Thanks (0) Thanks(0)   Quote essNchill Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2018 at 3:40am
Post Options Post Options   Thanks (0) Thanks(0)   Quote timeshock! Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2018 at 6:23am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pauly Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2018 at 7:16am
Done that already, couldnt find relevant info regarding colour codes or connection
Post Options Post Options   Thanks (0) Thanks(0)   Quote timeshock! Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2018 at 6:19pm
The likelihood is yours is a Japanese import and different form the European Models, However if you look on page GW74 you will see a diagram which show the wires peeling off the main loom to a connector terminal which in turn connects to the other connector which the wires disappear into the door. The wire colours are shown on all the diagrams eg GW-62 etc Hopefully you will be able to work out which joins to whichThumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pauly Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2018 at 10:52pm
Thankyou for your help mate, it us a map import, I'll give it a crack after work.
