Nissan Primera P12 engine misfires. |
tsakimak
NPOC Guest Joined: 07 Jun 2010 Location: greece Online Status: Points: 88 |
Posted: 08 Apr 2018 at 7:49pm |
I posted before but probably it's been erased because of wrong to the rules subject.
I own a primera p12, have done a lot of work on it, I am thr guy who made the day for the ecu fix and saving a lot of people paying money to nissan. But now I am really angry, over a year I am trying to find out why the car from time to time misfires, it doesn't happen all the time, it could happen if I drive normally one time in a week it could happen if I drive from 140-160km per hour.Yesterday engine light came on and blinking while I was driving at 150km per hour, Car lost power for 15 sec and after that engine light gone off and never happened again. This happened again, the garage couldn't find what happened because the fault wasn't stored. This thing will drive me nuts have changed maf, and crancksaft and camshaft sensors original ones, Spark plugs are new ngk, what could it be,? How can I check the coils if they are good as long as this happens for a while? Have grounded all the car straight to the battery, and have both tail lights ground fixed. This could be the time chain? How to check? The car is petrol 1.6 liters and has 134000km manual gearbox. Any help would be appreciated as I already put the car for sale , but I want to keep it because I have done a Lot of work on it. |
tsakimak
I also tried to enter the diagnostics with the throttle pedal and the engine light blinks four times x ten blinks so it must be 0000,which is nothing as I guess
tsakimak
guys nobody had similar issues?Propably i am cursed
roy.2
Hi. If you have changed the camshaft and crankshaft sensors its looking like a stretched chain.
Check the chain tensioner to see if it is sticking out more than 10mm.
tsakimak
thank you for the reply,i sold the car already just informed the new owner,have had enough of fixing it all the time,for me as a japan cars lover never had before a jap car that every month will need something to fix.Best regards
