  New Posts New Posts RSS Feed - Nissan Primera P12 gear box oil level check help
brett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brett Quote  Post ReplyReply Direct Link To This Post Topic: Nissan Primera P12 gear box oil level check help
    Posted: 06 May 2011 at 2:31pm
I have 2005 Primera.
How do I check the gearbox oil?
GaryeGT View Drop Down
Guinness Gaz
Post Options Post Options   Thanks (0) Thanks(0)   Quote GaryeGT Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2011 at 3:17pm
you empty it and put fresh stuff in. thats how
Post Options Post Options   Thanks (0) Thanks(0)   Quote brett Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2011 at 4:00pm
Sorry, did not mean to be so vague.
Could you explain where to drain and refill.
sjr4556o View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote sjr4556o Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2011 at 5:32pm
Wink Just changed my manual 6 speed transmission oil  easy job there are 2 plugs on the side of the  of the box  on the nearside(in  uk) the filler plup is nearer the front and higher adjacent to the front  engine mount the drain plug lower and to the rear near diff housing to check level park on level ground let the car stand for 10 mins after switching engine off remove lower engine cover first  to gain access to plugs  and remove upper filler plug the level should be just below the level of filler plug so if req,s topping up just add enough till it dribbles out of filler hole if changing oil total refill is a different matter as the hole is restricted so takes forever to fill I ended up using a 500ml syringe with a thin tube to get round the bend found it quicker & easier than relying on gravity to do the job.One word of warning if draining oil remove filler plug first as there done up tight as hell (snapped 1 hex socket on mine and twisted another) as if you drain it first and  can,t remove filler plug your stuffed with a transmission with no lube good luck.
crazy taxi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote crazy taxi Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2011 at 5:40pm
Good advice there ^^^^
Post Options Post Options   Thanks (0) Thanks(0)   Quote brett Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2011 at 7:57am
Cheers Fella.
Thats just what I was looking for.
jts11 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jts11 Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2017 at 5:06pm
Can you tell us what size hex key's do you need in case i have to buy several.
Regards,
Joshua
