Nissan Primera P12 : groaning noise |
Patel
NPOC Guest Joined: 22 May 2019 Location: London Online Status: Points: 1 |
Posted: 22 May 2019 at 7:28pm |
My car when moving at 50 mph gives groaning noise from front offside Could any one direct me what could be the problem and how to fix it
petterg
Wheel bearing? Worn tires or tire rubber turned hard? Sticky brakes? Maybe you could try to describe the sound a bit better? Is it at 50mph only, or at speeds above 50mph? Does it change with engine revs, gear selection, clutch in/out, braking, coasting, acceleration, turning the steering wheel? Maybe the thread I just started may give you some ideas as well? http://www.npoc.co.uk/forum/nissan-primera-p12-hollow-noise_topic80661.html
