  New Posts New Posts RSS Feed - Nissan Primera P12 Heater engine removal
Prynde View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Prynde Quote  Post ReplyReply Direct Link To This Post Topic: Nissan Primera P12 Heater engine removal
    Posted: 07 Sep 2018 at 7:28pm
Hi
I've been trying to remove the blower unit as described in the service manual but can't find the 2 location pins to remove. The unit does move around a little but can't say for sure what prevents it from fitting to come out except if it has to do with those pins.
Do i need to remove the ECM completly or is it enough to just unscrew the frame and push it to the side?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Prynde Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2018 at 3:01pm
Got the lower part separated now without removing the unit.
Seems the brushes are worn out from the motor.
Can the motor brushes be replaced or is it just better to find a new (used) motor?
Post Options Post Options   Thanks (0) Thanks(0)   Quote timeshock! Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2018 at 4:58pm
One thing is for certain, motor manufacturer will have a supplier for the brushes, so if it has brushes you can remove and identify you should be able to find some
