  New Posts New Posts RSS Feed - nissan primera p12 heater fan stays on
 Post Reply Post Reply Page  <1 234
rustler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustler Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2014 at 5:18pm
Cheers wickydude, and thanks a mill for all your help.
known84 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote known84 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2017 at 1:00pm
hey.!
i Have the same problem on my nissan primera p12 from 2002.
you say that you fixed the problem with the fan speed control module, is that another name for the resistor for the blower.
when i translate the controle module to the danish language i only get the resistor. But i could se that you already had changed the resistor, with no luck of fixing the issue.
thank you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote timeshock! Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2017 at 8:41pm
hi and welcome to the forumHandshake if your issue is the fan is on full all the time and not controllable then the issue is a broken resister within the fan control unit. Either replace the unit or effect a repair by replacing the resistorThumbs Up
thomasplant7@gmail.c View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thomasplant7@gmail.c Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2018 at 7:36am
I had a nightmare trying to get to the bottom of why my blower was permanently on. All the indications were that it was the blower resistor that needed replacing. Everyone kept telling me that it was behind the glove box WHICH IT IS NOT. In the end after going all around the houses I found it in the drivers footwell plugged into the ducting near the accelerator pedal.
I tried 2 Nissan main dealer's and no one could tell me this simple fact. Also, it is an easy 5 minute job to replace the blower resistor.
Hope this finally helps.
