Nissan Primera P12 Heater problems... |
Post Reply | Page <1234 9> |
chimeo
NPOC Guest Joined: 20 Mar 2007 Location: Cheshire Online Status: Points: 139 |
its not known as a fan control amp, ill get the name tomorrow, if your is the blower motor ill be very suprised,
maniclamb
NPOC Guest Joined: 10 May 2007 Online Status: Points: 22 |
Well the little white thing above the clutch pedal held in by two phillips screws is known as the 'Fan control amplifier' according to the Primera service CD, anyway I've ordered the part so hopefully it will cure it!!
Cheers. |
essNchill
^^ Keep us update please fella ^^
Cheers,
Shaun |
maniclamb
Will do , this cold and wet weather has really come at the wrong time for me.. Bit of mission trying to avoid the steamy windows scenario! Hopefully I'll have the replacement part soon. Will keep you all updated. |
maniclamb
Thanks for your help. Indeed it was the 'Fan control Amp' or 'Heater Reg' as they called it at the salvage place. I waited over a week for the part to come in at the local Nissan garage and decided to give up and risk getting a used part. It's soo nice to have warm/steamy-window free car back!
Kensai86
NPOC Guest Joined: 14 Jun 2007 Location: Leicestershire Online Status: Points: 865 |
how much did you pay for this part? as my heater controls only work on No.3!
sounds like a similar problem to you?
maniclamb
My fan wasn't working at any of the levels.. However people says its usually the cause when your fans only work at the top speed. I'm not sure if its a similar system for a P10? If so, then yes it could be the solution to your problem.
The part was listed at £27 + VAT from the Nissan garage, I got it little bit cheaper from the local salvage yard. I was getting bored of waiting for it to come in at the garage! |
Kensai86
illl get on the blower to nissan... cheers fella
DeeJ
NPOC Guest Joined: 25 Feb 2008 Location: Staffordshire Online Status: Points: 15 |
Can anyone give me the part number for the bcm module
arnie 818
NPOC Guest Joined: 28 Nov 2009 Location: North East Online Status: Points: 2 |
The heater fan stopped working on my 2002 Primera and on advice I changed the Module Assembly Power (resistor pack). It is located next to the clutch at the back of the heater outlet and secured with two philips screws. It took 5 minutes to change and cost £36 inclusive of VAT at my local Nissan dealer. This sorted the problem.
