  New Posts New Posts RSS Feed - Nissan primera P12 LH brake light not working
Oaks66 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oaks66 Quote  Post ReplyReply Direct Link To This Post Topic: Nissan primera P12 LH brake light not working
    Posted: 22 Aug 2017 at 9:41pm
LH brake light not working RH side works so does the hi level brake light.
Post Options Post Options   Thanks (0) Thanks(0)   Quote roy.2 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2017 at 9:53pm
Saloon or Hatchback or Estate?  Whichever, check the bulb first. Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oaks66 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2017 at 9:56pm
Bulb ok
Post Options Post Options   Thanks (0) Thanks(0)   Quote roy.2 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2017 at 12:32am
Wiring then, poor connection or bad earth. Ouch
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oaks66 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2017 at 5:46am
Thanks I will give it a go.
Noel IRL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Noel IRL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2017 at 9:53am
I have the same problem with my 2002 p12, it's a 'split bulb' so I'm told, parking light works but brake light doesen't (if that makes any sense)
NJD
Post Options Post Options   Thanks (0) Thanks(0)   Quote timeshock! Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2017 at 10:33am
Have you tried changing/checking the bulb, maybe swapping it with the working one?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oaks66 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2017 at 9:43pm
Have got LH brake light working I sprayed WD40 on the connectors and jammed a matchstick into the black wire part of the connector
